Can hub be connected to Wifi?
I can’t get my home monitoring hub to connect via Wifi only. I don’t want it to be connected via Ethernet cord. Is this possible? I can’t find definitive answers anywhere.
Yes, you can connect via wifi. That’s how my hub is connected. The only way I could get it to change was to go through the add device routine and re-add the hub (without deleting it first). During that process you should be able to select the wifi SSID and password. Just be sure that the ethernet cable is disconnected before you start.
Smart Man that @WildBill. :slight_smile:
Yes, there is currently a bug that says you can’t change it later. Seems it must be done during add.
Follow his process exactly.
Then you can go back & forth at will. Hopefully they will fix the bug soon.
