I’m sure this has been talked about a lot here but I’m new to the forum. My camv3 won’t connect to my home network that is compatible and also, I desperately need to update it as it is about a year and a half old. Any links or suggestions are greatly appreciated
Are you sure your phone/device is set to the 2.4GHz network only?
Yor app also needs to be current 2.50.2.442 (April 5, 2024) for Android.
You can load the firmware manually with a 32GB or smaller SD card in FAT32 format.
You need to follow the directions as written and rename the file. The V3 is the second paragraph.
