My outdoor cams with Cam + won’t record longer than 7 seconds even though I have them set for 5 minutes with no cooldown. All have the latest versions installed. Any advice? Thanks!
Try turning the distance and sensitivity up to the max, make sure you have no detection zone, and then wave your hands in front of the camera for a while. See if the video is still cut off at around 7 seconds even with obvious motion
