CAMs online are spotty
Is something going on with the Waze server? I have nine cameras that have been working flawlessly for years and for the past 24 hours they are going on and offline all the time. When I go on my Android phone to view them, they’re having a hard time connecting. When they do connect you can see the latest picture but the clock isn’t running. It’s like it connects up and stops. I have power cycled all the cameras. I have power cycled the router and modem just to make sure I’m starting with a clean slate. Never had problems like this before and now all of a sudden, out of nowhere, I have connection problems.
Since you have already power cycled everything, it helps to separate a network problem from a Wyze side problem. Next time they drop, open your router’s connected devices page and see if the cameras are still listed as connected. If they stay connected there but the app shows them offline, your wifi is fine and its most likely on the cloud side (there are a couple of other threads today with the same symptom). If they drop off the router list too, then look at wifi: nine cameras at once can hit the limit of a router or access point, especially after it updates itself or if it switched channels, so check signal at the weakest cameras and see if a fixed wifi channel on 2.4GHz settles it. Does it happen to all nine at the same moment or just a few of them?
VisuDock, thank you for getting back to me and for spending your time. I just want to give you a quick update. Everything is now back to normal. I haven’t changed a thing, so I am assuming it was something on the Wyze end. My cameras are spread out in two different countries and three different locations so they’re not tied to one router. I was having this trouble with all my cams, and now things are back to normal. Just wanted to give you an update that it is resolved. Thank you for your help.
