A magnetic small cube camera that is battery powered. It would be a three part assembly 1 a square piece of metal, 2 a magnetic base with a screw in ball swivel mount. 3 the wyze cube camera with a ball molded with the camera. The ball swivel would allow the ability to point and lock in a direction you want to camera to point. The magnet can be attached between tent material or the outside of a trailer home using the magnetic base. The camera would be about 4 inches big. It would connect to phone using wifi hotspot. So you could view what’s on the outside of the tent or camper while camping while in or away from camp.
Please make sure you vote for your Wish as one is not automatically added
I wonder what would keep you from using Travel Mode on the Wyze Wireless Outdoor Cam v1 or WOC v2 for this? If you had 2 WOZ cams pointed across your campsite you might have better views, as the tent wouldn’t be obscuring view of the lens.
