Cameras recording movement but show offline when want to look at live stream
Cameras recording movement but show offline when want to look at live stream.
Wyze Cam V2
Either the cam isn’t finding the Wyze servers or the app isn’t finding the cam (more correctly worded, can’t find, work correctly, connect, etc). Could therefore be a Wyze server issue, cam issue with the firmware, app issue, or router/network issue.
Easiest 1st step is to try a power cycle of the router and other wifi equipment you have.
Then try a reboot of the cam.
After that check for app update and cam firmware update and update as needed.
Can also try rebooting the device the Wyze app is on as that can sometimes help. Further, can try a reinstall of the app as in some situations that fixes things.
Other times too factory resetting the cam could be necessary,
Wyze support might be good to ask especially if you want to try to avoid some of the above.
Other things can be possible as well.
