I installed 2 cameras yesterday and have been testing them, I noticed that on both cameras if i try the 2 way audio the camera starts clicking looses connection with flashing blue and yellow lights and resets. Am I to close, can one unit hear the other ?
This occurs with both units
Is this a know issue ?
The clicking is the cam doing a power cycle most likely, it is the same noise when you enable nightvision.
What firmware do the cams got, and which cams are you using?
I have 2 Wyze Cam v2. Firmware 4.9.2.52. The noise starts as audio garble and then yes the click noise made by turning on night vision but repeatedly until connection is lost and camera finally restarts.
I thought maybe it was defective but it does it on both.
