Wyze app on Samsung S8.
I have two pan cameras as a group and a separate v2 camera. When I open V2 camera view in the app everything works OK. When I touch a group name to open view from pan cameras these views appear for a part of a second and then it turns the whole app off. How to fix this to be able to open camera’s view?
First thing I’d try is uninstall app, restart phone and reinstall app. Sounds like an app problem.
That was a bug. Update the app. It is fixed in the latest release.
@Omgitstony advice will work because the newest app should get installed.
Yes, app v2.16.53 fixed the problem without uninstalling the app. Thank you
