I have a camera group of 7 v3’s, lately when I open the camera group some cameras will not load , take a while to load live feeds, and some will have error code 90.
I’ll back out and refresh the tab, open camera group again and they’ll load perfectly but most of the time I experience these issues.
I’ve restarted all of the cameras through the app, and have power cycled all of them. Cleared app cache and force closed app yet I’m still experiencing the same issues. Issues started this week since I began using a Samsung Galaxy S20 FE.
Im using the v2.41.5 android app.
Any one else experiencing this? Any tips or advice to fix this? Thanks!
Yes. This has been noted. And for groups as few as 2 cams. Something changed in one of the recent app updates. I don’t get error codes, it just sits there and continuously shows “Loading Live Stream”
Clicking on the cam opens it and loads the stream, going back to the group then shows the stream. Sometimes backing out and reloading the group helps.
I have found that it doesn’t do it all the time. When it does though, it does it across all my groups.
Yea I also get cameras that get stuck at the loading live stream screen. Sooo annoying , for some reason backing out and opening the group doesn’t help.
Yesterday I had all 7 v3s stuck on that screen and had to wait 5 minutes for the cameras to eventually load
I’m also experiencing a weird events bug, when I watch some events in the events tab it’ll skip the first few seconds.
Hey guys , are you still experiencing the camera group issues?
When I open the camera group, I still get the pop up saying “failed to connect.” Error code 90 , on a few live feeds.
Simply by backing out of the group and opening the group again, or going up or down the camera group to view other cameras , or opening that specific camera with the error code will load the live feed but the bug is still affecting my cameras.
Yep, nothing has changed. Same issues. I can also confirm that the beta version 2.42.0 (a4) has same issues. Looks like nothing has been fixed. I just through the towel and raise my hands in the air.
For the last couple of years that I had my Wyze cameras, I learned to treat them as toys, not as security cameras. I’m OK with that, learning my ropes until I decide which way to go.
Anyone experiencing this issue, Wyze says they need logs to fix this and haven’t gotten any. If you’d like this to get resolved, here are the instructions to help out:
I’ve been super busy and I haven’t had the time but one thing im noticing is that they’re saying if it shows offline, mine only say failure to connect. Is that the same and do I still need to do all of their troubleshooting steps?
Yeah, they were just copying the standard scripting for how to get a MicroSD card log. It is usually asked for related to “Offline” cameras, which is why it says that, but the steps are the same and it is the same kind of log they are asking for here, they just didn’t update the wording from the standard script. Just ignore that it says offline as it is applicable to this error cod 90 issue too.
I just experienced that. However, it’s 10pm, dark, and 12 feet up to the cam on a ladder that is in the shed with no lights to fiddle with a microscopic SD Card. Not gonna happen this time.
