Just PM you:)
Just want to let you know that our developer had identified the bug from the log file you provided. Thank you for the bug. The fix will be in the upcoming official release.
For the timing being, if you are still seeing the flashing blue after power cycle, you can pop-out the SD card and then power cycle it. If this works, you don’t have to flash your hardware from a SD card, this is the temporary “duct tape” solution. Let me know if it works for you:)
Great to hear! Cameras came back online after couple hours, but thanks for the workaround solution! Waiting for bug-fix release.
