Camera feed not available
Hello everyone!
I’m a long time Wyze user and had pretty good success with Wyze 2 cameras and Google home, although I would need to reconnect them regularly.
However I’m running into more issues with the Wyze 3 cameras. Google Assistant can only show my cameras for about 10 seconds and only after I remove Wyze from Google home and then reconnect. Then I have to repeat the same remove and reconnect process to only see one camera feed for only 10 seconds, after which I get the same camera feed not available message.
All wyze products firmwares are up to date.
The cams work fine within the Wyze app.
Is Wyze no longer Google Home compatible?
Edit to add this issue exists on all versions of my cams not limited I just noticed it after adding wyze 3.
