After two months of light usage without problem, yesterday my camera turned on for short period of time and then shut off and does not turn on anymore. I have tried to plugged in and out several times with no luck. Does any one know how to fix it?
Do you hear a clicking sound?
Test the power supply/cable with other device
I did, and it works fine with other device.
yes but at middle of camera revolving stopped working and did not turn on again.
This sounds like a probably return case, although you might want to try a factory reset.
Keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, I suggest you file a support request including the log files for more help. You might want to go ahead and submit your ticket now as there is somewhat of a backlog. If you end up getting the issue resolved before support contacts you, then you can always let them know that it’s already resolved.
