Not sure where to ask this. Please suggest different forum if there is a better place. I need to buy a new light fixture for our hallway/living room (all one big room) and the V3 is mounted close to the ceiling.
Question: Can I use clear lamp glass over the bulbs or should it be frosted? Does clear bulbs or glass over bulb fixtures create more of glare than frosted glass?
Maybe describe in more detail what you are concerned about. Frosted bulbs in general cut down on the harshness.
Maybe provide a photo?
If the light shines directly into the camera you may have difficulty with contrasting other items.
If light is far enough away, it might help with clarity.
I haven’t ordered the lamp yet. That’s what I’m trying to figure out. It’s called flush light? I might have to just order 2 and try them out. haha. So sorry I don’t know how to explain it better.
