I’m chiming in as I seem to be having a similar issue as the OP.
Rewind back a few months, I have set up a new temporary 5G home broadband connection, with TPG in Australia. The 5G modem is the ISP supplied Arcadyan Wifi 7 modem.
The V4 cam was one of the first devices I was setting up. Exactly the same problem as described. The 5 GHz band was already disabled, SSID for 2.4 GHz band was broadcasting and during the set up process with the app, it would see all of the neighbours’ networks, except for mine centimetres away. My phone had a solid connection to the wifi. Tried everything, rebooted so many times, and the last thing I did from memory was removing the SD card I’ve put in at the beginning. Then another reboot later, it saw the wifi network and setup was able to continue.
Fast forward to yesterday, I had to reboot the modem as a new device was not connecting. Once I got the new device to work, then the V4 wouldn’t connect! Same issue as above – the app couldn’t see my own wifi network. Tried rebooting multiple times, also tried downgrading from wifi7 to wifi6, but nothing worked. However, I did not touch the auto channel and the auto 20/40 band settings.
I was able to give up and I thought I would give the SSID setting a go. I turned SSID broadcasting to off. Modem rebooted and even my phone couldn’t see the network. I turned SSID back on and lo and behold, and after a reboot, the Wyze app could see the network and was able to continue setup successfully.
So conclusion is, I still don’t know whether it’s a modem/router issue or Wyze V4 issue. I don’t want to have to play around the modem settings every time.
In a month or two, however, I will be back having a fixed broadband connection with my old Orbi router, so hopefully I wouldn’t have this issue when I tried connecting the V4 again.
What do you think brains trust?
