Cam V4, V3, V2, outdoor cam, battery cam pro + solar reliability (+cold weather)
I have used a bunch of wyze cams outside in the last five years and this is my long term experience with them. (bad neighbors are good wyze’s customer-makers)
I live in rural Canada with -40 to +30 Celsius (extreme cold to warm temperatures)
I used all wired wyze cameras under eves
I have two battery cam pro cameras on trees with solar chargers facing south
I have a battery cam pro and an outdoor cam sitting outside 95% of the time-my wife likes to observe wildlife
I used factory power adapters, wires and solar panels only
I used to have three v2 cameras, they worked for 2-4 years then died
I have 2 v3 cameras currently, I believe I had one or two that died after 2-3 years
I have 3 v4 cameras currently operating, the oldest about 8 months old. Another 3 v4 cameras died within a couple weeks of use in the cold.
V4 reliability is a big downgrade. I was used to cameras failing, but v4s give me too much hassle, So much actually that I decided to subscribe again to my nest subscription (that I H.A.T.E for pricing) because my nest AI outdoor is the only reliable wired camera facing my driveway.
Fun fact is that all my three V4s that failed were facing south (somewhat into the sun), at least two emitted loud buzzing sound on very cold days before failing. Some say the seals/glue in these cameras is the culprit, It might be.
My experience with ALL wired camera SD cards is bad. Eventually sd card failed and the cameras won’t notify you when an SD card “diapers”, I usually figured out the hard way, when someone uninvited was at my door for example. SD cards tend to oxidize inside the cameras, some were unable to read new cards after this.
Some of these cameras surprised me with doing things like resetting to the default 12-second videos, or snapping a photo instead of a video that they were actually claiming to have taken. Again, some of these issues were found out when I really needed those recordings..
The increasing hassles with maintaining these cameras drive me to the point where I decided not to bother any more. I have a replacement v4 in its original box (two replacements broke already) and about 100$ in coupon that I got back due to another issue from before and I’m not intending to use them.
I understand the temperature range I’m using them is well outside the limit wyze is advertising, so take this as a good advice to a good amount of fellow Canadians here.
What I like though are the battery cameras. Yes, they die under -30, but come back alive once it gets warmer. Wife is complaining about alleged missed videos due to sensor sensitivity or maybe a degrading sensitivity, but I cannot really confirm if it’s a big issue.
Oh, and I used to have door/window opening sensors with the v2 cameras (they used the cameras as bridges) but had to phase them out as the v2s failed. I bought new sensors, but they now required a separate bridge that I refused to buy (not to mention the outdoor cam needed ANOTHER different bridge). This inconsistency didn’t age well either.
At this point I’m slowly phasing ally wired cameras out. They break often, the SD card dies or do weird stuff that requires too much attention and time. I am keeping the battery cams, they are fun toys. And this is the final verdict. Wyze cams were affordable and fun for a while, but if you want to rely on them for security, unfortunately I can’t recommend them.
What are you replacing your wired Wyze cams with that survive your climate? Analog CCTV?
-40c is way way outside the operating range for these cams, so can’t really be surprised that they had issues. They’re rated for -20 which is probably pushing it. I think my cams may have hit less than -20 on a few occasions but it was just for a night or two. They do get direct afternoon sun in the summer but that’s probably a peak of 40c max. Direct rain, snow, and ice though (most aren’t under eaves) and have handled that like a champ.
Have you considered building a small enclosure (or getting a pre-made one)? The heat the cam generates may keep it warm enough in there, and also should cut down on condensation when the temperature changes.
Actually, I am leaving soon. So I’m not replacing them. The wired nest is reliable, I will keep that one to monitor my home, plus some of the battery ones with solar panels - understanding they won’t work in the cold.
With that said I would be really curious what others use in the cold climate.
We used analog CCTV bullet cams in Fairbanks and Adak, AK. Most civilians ran cheap IP cams through double-pane glass with external IR emitters.
