Cam v3 IR lights won’t turn on if Lamp Socket is on
I have a cam v3 connected to a Lamp Socket. The Lamp Socket has a smart bulb in it. In order for the smart bulb to remain reachable and operational on the network, the lamp socket must be set to always On instead of Auto. This allows the bulb to be turned off even if the socket is “on.” However, when the connected socket is in the On state, the IR lights on the cam v3 do not turn on when Night Vision is on. Changing the IR lights between Off, Near and Far has no effect. The IR lights will only turn on when the lamp socket is turned off. I would like to have the IR lights continue to function even when the socket is on, so that I can have clear night vision in a situation where the bulb is being controlled independently from the socket.
