@Herohtar Take a look at this WiFi switch. Its not the traditional plug. You can put this inline to your Romex. And use an app or your voice to turn it off/on. These are cheap. I use them everywhere.
Thanks Brudda. I’ll def give them a shot!
Its not just that either. The cameras may disrupt but the main thing is that the Wyze streaming eg in the app gives up and won’t keep going. Sometimes that works better on different devices. But that’s not good if you want the cam to keep streaming.
However, I set the cam v3 and v3 pro up with Amazon Alexa and when the cam disrupts it, Alexa will auto try again every 2 hours. And it always starts again. Best free way to stream that I found for what I want.
Power cycling or restarting isn’t the best way to go since that’s not actually needed but it is also a solution. Its also manual and terribly annoying lol.
They’re just le garbage. Mine does the same thing all the time. This summer I’m trashing the lot and going with Blink
