Cam Pro card issues
After the app update, my Cam Pro isn’t recording events. I’m just getting a snapshot. I have an sd card. Another HH member hasn’t updated the app in a long time and has zero issues.
If your household member’s older app still shows the full video for the same Cam Pro events, the clips are being recorded and it is the new app version that is only showing the snapshot. In that case I would force close the app, clear its cache or reinstall it, and log back in. If they are not seeing video either, check in the Services section under Account that the Cam Pro is still assigned to your Cam Plus plan, since event videos come from the plan and without it events show only an image. The SD card records separately, so you can confirm it is still working from Playback in the live view.
I don’t have cam plus. I use the sd card to see the short videos. I’m not seeing those anymore. Just a snapshot. I’ve cleared the cache, reinstalled the app but when I tap an event and choose sd card, it takes me to the live stream. If I scroll through the timeline at the bottom it shows symbols for events, but says no video available. HH member still gets short videos.
