Cam plus upgrade not showing on V2
I just upgraded my subscription to cam plus for two cameras.
My WCO shows the upgrade but my V2 is not showing cam plus upgrade in the event recording tab.
Yes I activated and check off on both cameras in the app.
Any suggestions
Thanks
Hi @pete454ss Its usu the other way around WCO vs V2 :slightly_smiling_face:
Check iOS app is on v 2.14.23 (October 21, 2020)
and V2 on Firmware version 4.9.6.199 (October 21, 2020)
Check time is correct on all cams.
Time and firmware are up to date.
The cam plus upgrade is not showing up on the V2 camera.
The cam plus upgrade is showing in my WCO.
