Cam Plus and Alexa
Is there a minimal amount of time before can use cam plus with Alexa? I purchased cam plus about 15 minutes ago. Set it up with a wyze cam, that I can see using Alexa. I set up the wyze cam to enable person detection but when I go to Alexa routines it says it is not enabled and to check my wyze app.
it was a timing issue. it is working now… thanks anyways.
