I accumulate dozens of 12 second videos on my outdoor camera and hate deleting them one at a time. A delete all feature would be wonderful!
Welcome to the Forum Community, @edfisher07.
You can already bulk delete in the App. From the Home Screen select:
Events/Pencil Icon (in top right corner of screen)/Select All (upper right corner)/ Delete (lower right corner). This will let you delete at one time.
Since your #wishlist item was actually about existing ability your post was moved to this category.
Great question and thanks for your post!
You should also scroll to the bottom of your clip list first, or you will only be deleting 20 clips at a time.
Also, the 12-second cloud clips will expire with no action on your part after 14 days. So you can also just let them evaporate on their own if you like.
