Bulb cam pan tilt detach issue
Is it possible to detach the telescopic pole from the camera so that I could fit it into a lamp that has a small opening. Then re attach it. I see some little clips on the top of the pole.
No, you’d end up destroying it, even if you managed to get it apart there are wires running through there that would need to be disconnected internally somewhere.
