After upgrading to the latest firmware and software the payback has a lang of almost a minute. When you use the slider arrows or drag to a particular point the video lags behind so much that it has become unusable.
Don’t know when this problem is going to be resolved.
Most likely this is a result of them removing the hardware decoder from the app.
In the mean time you could roll back to the previous app version 2.4.82 it would probably fix your problem.
You can find the file in the link , you must uninstall current app before installing the app from the file. https://support.wyzecam.com/hc/en-us/articles/360009818512-Android-Wyze-App
For further assistance you can submit a support request here Support Request
apple typically does not allow roll backs I don’t think. that would “comprimise the added security of the update” or something to that affect I’m sure.
