I have 7 Wyze battery cams 3 on one network and four others 2000 miles away. All cameras and base station have the latest updates. The issue is they are always trying to connect to video but never do. I can turn them on and off remotely so I am communicating with them. One weird anomaly on each network is that only one camera on each network will connect the rest time out. What could be the issue?
I am using IOS devices to connect. Anybody have an idea what is going on? This just started happening about a week ago.
Do you by chance have the camera in a group? if you do, Can you try removing the camera out of the group to see if that fixes it?
Sounds like an idea! But only see how to remove the whole group. Can I remove just one camera? If so do you know how?
When you call up the settings of the group, you’ll see a “Cameras in Group” number. Press that, and press the red minus sign on the camera you want to remove from the group.
Yea right after I wrote to you I found that. Anyway that did the trick! They now load. Thanks so much!
