Battery Cam Pro is getting frequent connection errors. Last firmware update was August 24, 2026 1.4.5.6553.
“Failed to load from cloud server, You can view event from your backup local storage” or “Error connecting with cloud. Try fetching and reloading”. It’s happening more often than not and nothing seems to be happening to fix this bug.This isn’t happening on any of my other cameras, just the wireless and I only have one. Anyone else experiencing this problem?
Since it’s only the battery cam, I’d look at its Wi-Fi signal first. Battery cams wake up, record and upload the clip in a short window, so if the signal at that spot is marginal the upload can fail and the app can’t pull the event from the cloud, even though it still saved to the SD card. The camera’s Device Info should show the signal strength. If it’s weak, moving the router or a mesh point a bit closer might clear it up. Clearing the app cache is also worth a try in case it’s on the app side.
