Trying to connect a base station to my router, but I can’t get a solid blue light. It’s plugged into the router and to power. The light is yellow, then turns to flashing blue and yellow, which is supposed to be the camera pairing mode. I need solid blue. All cameras in range are turned off physically, I’ve tried a couple different cat5 cables. The router and internet is working. I’ve rebooted both the router and unplugged/restarted the base station multiple times, even pushed the reset button. Nothing helps.
This is my 2nd base station, I have the first one in my house, that’s connected directly to the router in the house. That router has a 2nd router connected to it and that router is in my shop building. I’m connecting this new base station to the 2nd router. Can this not be done? I can’t connect to the house router as it’s too far away for the signal to work, plus I’ll have more than 4 cameras total.
Well I would say it’s now corrupt, if nothing happens after a few hrs do a warranty replacement at Wyze, if out of warranty trash it and buy another one, I have seen them used/new on ebay cheap
Have you tried repairing a camera with that base for troubleshooting since that’s what it wants to do? Has that base station been set up before on your system?
No, and I can’t access it at all. I just took everything out of the boxes yesterday, charged the 3 cameras (didn’t turn them on)
The 2nd base station doesn’t show up in my list either.
