If Android restarts or updates auto-unlock fails until app is opened.
One thing that might help with this is to go to the Account tab, click on app settings, then toggle on the setting “Running in the background.”
This might help make sure that your phone allows the app to continue functioning.
You can also check battery optimization settings.
Some phones will not allow apps to do anything until you open them again after a reboot, and that is more of the phone’s fault than the app. The phone is trying to help do what it thinks you want, but in this case it is guessing wrong and stopping the Wyze app from running in the background until you open it again. Selecting this setting might help get the phone to allow the Wyze app to continue running in the background like you want it to.
