Anyone having trouble with detection zones on the pan cams? The app crashes or sends a message that the feature is not supported, if you try to turn it on. Regular cams are fine. I had these set up previously but something changed after the last camera firmware or app update.
I setup my first Cam v2 (regular, not pan) and I have the same problem in the app. Cam was updated (4.9.3.64), I am using Android app v2.0.26 with Android 8.1.0, security patch level Dec 5, 2018.
When I go to camera settings, Detection Settings, the app locks up most of the time. Sometimes is says that it is not supported.
I have no SDcard installed yet.
I am impressed with cam so far. But to get another I’ll have to get detection zone working.
