Allow Network Change for All Cameras At Once via App
Hello - Just bought a new Router. Setup w different SSID and Password. Unfortunately, now all cameras are “offline”. Can’t change Network under Setting, Device Info. It’s greyed out. Looks like I’ll have to delete each camera and add them back. That’s for each of 12 cameras. It would be much better if the app allows to change network in Device Info. Better yet, allow wholesale network change to all cameras by selecting all cameras in the main app. Thanks!
Welcome @obioneknobi
You will need to go through the setup again to change the SSID on it. However, you do not need to delete the devices as this should save your settings and automations.
The other alternative is to put the SSID back to what you had and the password as well.
Welcome to the Forum, @obioneknobi! :wave:
In addition to what @spamoni noted, some Cams can change networks from their individual Device Info screens as a result of recent app and firmware updates. I don’t know what the plans are for expanding this to other Cam models. Also, there’s an existing Wishlist topic that addresses your suggestion:
As with any Wishlist topic, you can visit that one to click or tap the Vote button above the initial post and share your ideas and use cases in the comments to show your support for the product and feature request/suggestions that are important to you.
