Hello,
In the last day or two, with no other change in my system, all of my Wyze cameras (mostly Wyze Cam V3) have started freezing or having dropouts. (I don’t really know what to call it when it is showing 18:21:14 and then the next timestamp jumps to 18:21:20.)
My internet speed is exactly the same.
All of my mesh routers are the same and seem to be working properly.
This is showing up on both my iPhone and my iPad, so it doesn’t seem to be a device issue.
I have restarted several of the cameras multiple times without any success.
Although I am not sure, this may have started with the latest app update from a couple of days ago.
Any ideas would be greatly appreciated.
Thanks,
Dave
If both iPad and iPhone are on the LAN, it has nothing to do with your internet speed. It has everything to do with your WiFi. Did you try rebooting the router and all its nodes?
Thanks.
There is a recent update to my router firmware, so when I update that they will reboot.
However, I switched my laptop from WIFI to ethernet, and reduced the image quality on the cameras I watch the most down to 360.
One or both changes seemed to help.
I appreciate your suggestions.
