I have two units, one is about 2 years old, the other is 4 years old. They both have developed fan noise. The newer one about 6 mths ago and the older one just in the last week. Both are current with firmware, both have new filters installed. I took the filters out and blew out any dust with compressed air and looked for anything that appeared to be loose. No help. I am using one for white noise in the bedroom which is fine when the fan is turned up ( which I have to do manually as there is no rule for that) but when it goes back to Auto ( which I can use a rule for!) it still has this rattle. The other one is in a busier part of the house as it did not work in my office where I want quiet. Do they just wear out or is there some maintenance I need to do without disassembling it?
I think this is mostly bearing or motor wear, since a rattle that only shows up at the lower Auto speeds is common once a small fan gets a few years on it. One thing worth trying before giving up is checking that the filter is seated flat and the back cover is fully clicked in, because a slightly loose filter or cover can buzz at certain speeds and not others. Also try running it on a different surface or lifting it slightly, in case it is resonating against the floor or a table.
If it still rattles after that, I would contact Wyze support. A 2 year old unit might still be covered, and they can tell you if a replacement fan is something they offer. I would not open it up on your own unless you are okay losing the warranty.
