I recently bought 2 air cleaners.
They setup fine and do a great job.
Firmware updated to current rev before use.
They will both lose WiFi connectivity after a while and the only way to re-establish connectivity is to unplug/replug.
I’ve re-paired the devices multiple times - same result.
I have all my Wyze products on a dedicated mesh network - I’m not even close to maximum number of devices.
Sniffer traces don’t show anything unusual.
No routing or switching is in place that would impact this.
I’m running 1gb fiber internet.
At this point - I have to use a Wyze plug on each air cleaner to power cycle and manage the devices which is crazy.
Does anyone know of a more reasonable solution?
The latest Firmware update seems to have introduced this. Wyze has been made aware, I believe. I would contact Wyze, get a ticket and provide a log, if you have not already.
I got an air purifier a week and a half ago and I am also having this issue.
Have the same issues as SolarDave every week, having to uninstall and re-establish the WiFi connection with the Wyze app. My Wyze air purifier is literally 15 feet away in the dorect line of sight from my Amplify Alien WiFi 6 router, but the connection keeps dropping. Has Wyze addressed this issue yet? The Wyze Air Purifiers just went on sale; was thinking of getting a 2nd one, but not if this software bug can’t be solved.
I too have this issue.
Oddly, it didn’t start to fall off the wifi intil i replaced my router with a brand new wyze 6e mesh router. I used the same ssid setup so all wyze products moved to new router without any issues.
I’ve had this issue for over a year. They just go offline randomly. I have 2 of them. I don’t have issues with my cameras losing connection or my bulbs, but these air purifiers…
At least they’re somewhat easy to get reconnected. But I wish they’d figure out what’s causing the frequent disconnects.
