After 14 Days?
After 14 days what happens to stuff on the cloud?
It gets overwritten and is gone. Only the stuff on the 14th day into the 15th.
https://support.wyzecam.com/hc/en-us/articles/360019931011-How-does-the-free-rolling-14-day-cloud-storage-work-
Thank you for the information
I enjoy the products so much
No problem, I enjoy them as well. Over and above some commercial grade systems.
A different question
Is there a way to setup a couple of way points?
Thank You
Stephen Somogji
What are you referencing?
With regard to the Pan Cam, you can set up waypoints using the Pan Scan feature. See below:
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwi4wtjSUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiPS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMTk3MDY1NTItUGFuLVNjYW4tTW90aW9uLVRyYWNraW5nBjsHVDoOc2VhcmNoX2lkSSIpZmMwZGY5ZWEtYTQ5MC00YWE2LWE0YjMtMjFkZWFjZDU1ZTZkBjsHRjoJcmFua2kG--5e8e6b57e9f90b8317bb1c3b9605064a7f943140
Other than the fact they don’t support Ethernet.
If you have a strong WiFi and decent bandwidth, you really don’t need the hard line.
Even so, I have an enterprise WiFi system with a 400/200 internet speed and still simultaneous rtsp LOCAL streams still put way too much pressure on WiFi networks for long term or permanent use.
I can’t access the site. An ‘OOPS’ page comes up. Any suggestions?
