# Adding a door chime/alarm
**URL:** <https://forums.wyze.com/t/adding-a-door-chime-alarm/110415>\
**Category:** Cameras\
**Created:** [July 3, 2020, 7:14pm UTC](https://forums.wyze.com/t/adding-a-door-chime-alarm/110415 "2020-07-03T19:14:36Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![notromlv82](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/notromlv82/32/54666_2.png) [@notromlv82](https://forums.wyze.com/u/notromlv82)\
**Post date:** [July 3, 2020, 7:14pm UTC](https://forums.wyze.com/t/adding-a-door-chime-alarm/110415/1 "2020-07-03T19:14:36Z")
</div>
I have a question? Im thinking about getting a alarm/door chime to use with my WYZE contact sensors and WYZE plugs, i found something on Amazon but not quite, i would love if it worked with WYZE, Any Ideas??
[https://www.amazon.com/Monoprice-Wireless-Smart-120dB-Siren/dp/B07N8LCNJ5/ref=pd\_sbs\_421\_5/144-2758886-8233153?\_encoding=UTF8&pd\_rd\_i=B07N8LCNJ5&pd\_rd\_r=488b349b-f6cc-47ec-a40a-8cc6a6f1f195&pd\_rd\_w=1Cmbv&pd\_rd\_wg=ulKLx&pf\_rd\_p=bdc67ba8-ab69-42ee-b8d8-8f5336b36a83&pf\_rd\_r=PT1B4QYB9TT9PCB9TVCR&refRID=PT1B4QYB9TT9PCB9TVCR&th=1](https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.amazon.com%2FMonoprice-Wireless-Smart-120dB-Siren%2Fdp%2FB07N8LCNJ5%2Fref%3Dpd_sbs_421_5%2F144-2758886-8233153%3F_encoding%3DUTF8%26pd_rd_i%3DB07N8LCNJ5%26pd_rd_r%3D488b349b-f6cc-47ec-a40a-8cc6a6f1f195%26pd_rd_w%3D1Cmbv%26pd_rd_wg%3DulKLx%26pf_rd_p%3Dbdc67ba8-ab69-42ee-b8d8-8f5336b36a83%26pf_rd_r%3DPT1B4QYB9TT9PCB9TVCR%26refRID%3DPT1B4QYB9TT9PCB9TVCR%26th%3D1%26fbclid%3DIwAR24vUsc7dlmIAfMUC0v1l1SZeXE5xoDsbQhW14kvwUwwmjVjeObNHBaY1A&h=AT1eLOdjMk-IM0dc-TqEHduaGxIpn5yvo4IpnPMaqpTHhMC64PpltRXwSFelyn2WVbM3d85AmED733ylIyvuz_jKupUPrKBV3IvEMncYRS9CQQe25KIBLhReqaR_AF7L05yb& __tn__ =-UK-R&c%5B0%5D=AT2FCG5G-jmKew0uqV5RMM53JToIGojdNRDoPL0mfRO7d_XatTGvj8v-wFLGJObjmNa2YlWcYpLiS-CGigRUMVr2imZJVrSU6SFzZSSo8Wuz49xgVaB6fU8oXRX3LbimahMXfygXm30DDOpdz1TZx8GB3-sXtienMg)
**Author:** ![Brlepage](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/brlepage/32/21184_2.png) [@Brlepage](https://forums.wyze.com/u/Brlepage)\
**Post date:** [July 3, 2020, 10:00pm UTC](https://forums.wyze.com/t/adding-a-door-chime-alarm/110415/2 "2020-07-03T22:00:09Z")
</div>
**Welcome to the Wyze community!**
I **don’t have much experience with chimes/sirens** but I’ll try to help the best I can! This works with Alexa so it _should_ be able to turn on when a motion sensor or contact sensor is tripped. Another recommendation would be to get a [plug in siren/chime](https://www.amazon.com/Wired-Outdoor-Bracket-Security-System/dp/B07P1FNJTG/ref=sr_1_3?crid=1JPPCRYJ8IC5H&dchild=1&keywords=plug+in+siren+alarm&qid=1593813587&s=electronics&sprefix=Plug+in+siren+%2Celectronics%2C168&sr=1-3) and plug it in to the [Wyze Plug](https://wyze.com/wyze-plug.html).
**Edit:** The siren I linked was more of a security alarm. I couldn’t find a plug-in chime that would work.
