I came looking for help on this. This is an older post and I can’t tell if this made the list or not. I did lots of searching. This seems to be the best place and most recent request.
It seems super Simple since ‘on’ already exists just adding an option for ‘off’. @Loki
Can we add heat/cool ‘off’ triggers to the request for development list?
Just got my scale yesterday!
I was surprised to see it was not under the triggers in the rules.
Can step on/off scale be added to triggers?
Or maybe a trigger that fires when your info is synced to google fit?
Automatically close garage door if open for x minutes
Is there an option do to this? If not, please consider adding this functionality. Very useful b/c my wife usually forget to close tha garage. And we do not have notifications turn on during the day since it’s annoying to have lots of notifications.
[Mod Edit]Merged with an existing wishlist topic. Give it a vote to help it along!
I am surprised that this has not made the list, Wyze Thermostat can turn on something when heat or cool is requested, but there is no way to turn something off when the thermostat says it is done? A thread I found that is pretty old https://forums.wyze.com/t/wyze-thermostat-to-control-wyze-plugs/134522, my reason for the request is that I wanted to turn on a Wzye plug when heat or cool was called for (I can currently) to turn on a couple of fans to move the air around, and when the heat or cool turns off turn the fans off ( I currently can not do ).
[Mod Note]:Moved to “Triggers” from “Actions”. Please note existing request in 1st post:
This is for the Cam Pan (v1/v2), but should apply to other Wyze cameraa.
I know that when the live stream of a camera (at least on my Cam Pans) is being viewed, the camera light turns from blue to red. So the logic already exists.
Create a new trigger for rules: “When live video is being viewed by a user”.
This can be used to trigger an action (turn on a light, turn on a plug, or other action).
Another new useful action that could be added to use with this trigger is to play a sound (once or recurring) to alert people that the camera is being viewed. I’ll make a separate suggestion to play custom sounds.
Thanks.
I would like to have a rule trigger for V3Pro that allows me to set the Spotlight status to “Auto” instead of just “always on” or “staying off” so that I can set it up as a trigger or shortcut or schedule.
Rationale/Example:
I have a V3Pro in my family room and normally I like having the spotlight on Auto to double as a night light. BUT we have a baby swing in that room, so when I try to have the baby take a nap in there and turn off the lights to the room, the spotlight is continually triggered by the swing and shining right in the baby’s eyes. I have to manually go into the settings and switch the spotlight off of auto to off. Then after the baby’s nap is done I have to manually go set that back up on auto. It is tedious. I would love to be able to schedule when the spotlight switches back to Auto automatically, or set it up so that when I flip a contact sensor or push a shortcut it automatically turns the spotlight back onto “Auto”…currently we only have the option to turn the spotlight on or off, but I’d love to be able to decide when to trigger the spotlight to “Auto” instead of permanently on or staying off.
Ability to turn on/off cameras when you arm away, arm home, and disarm. This way for example when your home you can have your indoor camera(s) off and when you arm away they turn on
Cam pan v3: Setting up triggers. I have two cams setup (driveway and front door both basic v3 cams) if either detects a person at night the sirens on v3s and v3 pan all go off.
Would be nice if we could set the pan cam to turn to a certain position when a specific event is triggered. Then have it turn back to it’s original position (a user set home position) after set amount of time.
Seems like plenty of votes especially when you consider other wish list votes from closed / combined Wishlist items
Perhaps this Wishlist is too big for Wyze to consume all at once?
I’s like to selfishly ask that rules or shortcuts get tied to the HMS so I do not have to do two things when arming/disarming my system
1.) Arm the system
2.) run my short cut
