# Add letters to lock/bolt keypad buttons
**URL:** <https://forums.wyze.com/t/add-letters-to-lock-bolt-keypad-buttons/234060>\
**Category:** Probably Not\
**Tags:** lock-bolt, lock-keypad, probably-not, lock\
**Created:** [June 27, 2022, 4:18am UTC](https://forums.wyze.com/t/add-letters-to-lock-bolt-keypad-buttons/234060 "2022-06-27T04:18:25Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![ndfall](https://avatars.discourse-cdn.com/v4/letter/n/d9b06d/32.png) [@ndfall](https://forums.wyze.com/u/ndfall)\
**Post date:** [June 27, 2022, 4:18am UTC](https://forums.wyze.com/t/add-letters-to-lock-bolt-keypad-buttons/234060/1 "2022-06-27T04:18:26Z")
</div>
This may not sound very significant to you all, but it’s very meaningful to me so I share.
It would be great to have the numbers on the pad include letters like the dial pad of telephone. This makes it easier to remember a number, by creating a sequence of numbers like letters.
so if my code is 87246 it could be easily remembered as “TRAIN”. try it!
**[Mod Note]:** _Title changed and topic moved to the #wishlist category for better visibility since it involves a product enhancement by Wyze. Please remember to scroll up to the top and click the VOTE button._
**Author:** ![IEatBeans](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/ieatbeans/32/33378_2.png) [@IEatBeans](https://forums.wyze.com/u/IEatBeans)\
**Post date:** [June 27, 2022, 6:48am UTC](https://forums.wyze.com/t/add-letters-to-lock-bolt-keypad-buttons/234060/2 "2022-06-27T06:48:14Z")
</div>
Great idea, you could use the #wishlist to add your suggestion. Make sure to hit the green VOTE button.
**Author:** ![Seapup](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/seapup/32/118966_2.png) [@Seapup](https://forums.wyze.com/u/Seapup)\
**Post date:** [June 27, 2022, 1:23pm UTC](https://forums.wyze.com/t/add-letters-to-lock-bolt-keypad-buttons/234060/3 "2022-06-27T13:23:27Z")
</div>
> [@IEatBeans](#):
> Great idea, you could use the #Wishlist to add your suggestion.
I agree… great idea. 👍
