To be quite honest, I’m not even sure if it is realistically possible to allow the current Wyze Lock Gateway and the current Wyze Lock Bolt to communicate with each other directly from a technological standpoint since I believe they use different radio standards:
It was my understanding that the Gateway uses WiFi to connect to the router, and Zigbee to connect to the lock, and then the phone connects to the lock in one of 2 ways:
- Through the internet to the router then Wifi to the Gateway then Zigbee to the Lock
- Bluetooth to the lock directly.
- I don’t believe that the Gateway itself even has a Bluetooth radio (if someone finds otherwise in the FCC docs or something, please let me know).
- The Lock Bolt I believe only has a Bluetooth radio, and doesn’t support Zigbee or WiFi.
If both of the above things are true, then the Lockbolt can never connect directly to the lock Gateway. They don’t even have the same radio (different modulation techniques and protocols). Wyze could do a work around and make it connect to an active lock which then connects to the gateway, but then the battery life on both the lock and the lock bolt would be reduced a lot more, which would likely make people upset. And it also means people couldn’t replace the lock with a lockbolt since the lock would still need to be active. Though there are some of us (including myself) who use both a lock and a lock bolt at the same time, there are probably not a lot of people who have both the original lock and the Lockbolt both deployed at the same time, so it would also frustrate people who have a lock bolt, and don’t need or want an extra original Wyze lock deployed being told they’d have to get the other lock too and keep it active, or that they couldn’t just replace it because that other lock still needs to be active to provide the Bluetooth connection to the gateway. A lot of people with less technical education wouldn’t understand that there are different radios in the 2 devices which prevent the gateway and lock bolt from connecting directly to each other and think Wyze is trying to force them to pay for an extra lock that they don’t need or want.
Since Wyze has apparently figured out how to connect the Lock Bolt to the Chime they already produce, which uses Bluetooth itself directly, this seems like it could be a reasonable solution if they sold the chime separately (which they don’t currently do). The Wyze VP implied in an AMA that this was the direction they were taking:
Especially if they are considering giving WiFi access to multiple products besides just the Lock Bolt, it would make sense to have one thing that can work for them all. Maybe the scales, and floor lamp and lock bolt, and anything else that needs a base or hub or gateway.
As I have said, I am supporting this wishlist, I have advocated for this, and I have 3 Gateways I could use, so I would love this. I am just saying that I don’t know if it is even possible since it may be that the Gateway uses Zigbee and the Lock Bolt uses Bluetooth. Wyze may basically be forced to be practical and use another device that actually supports Bluetooth, like they appear to be doing with the Chime. Now, if we can just get them to start selling the chime separately at a good price and not have everything go through the Video Doorbell Pro screen, that would be awesome. I am guessing that will be something that will be considered more in 2024 though, since Wyze said they putting their focus on their original basics of cameras and improving the app as a priority this year.
Though to be clear, I don’t represent, nor speak for Wyze. I am just just hypothesizing from other information I have read from them publicly in AMA’s and the technical specifications I have read about from the 2 devices.
EDIT/UPDATE: As clarified in a post below, the Gateway DOES have Bluetooth, so it looks like it does have the technology needed to make this happen. That is good news.
