Add direct control to floodlight in cam floodlight pro
The device is called a floodlight but can only be controlled as a camera. It needs the ability to control it as a light. This way it can also be included in a group of lights.
The expensive floodlight pro can work as a traditional cheap dumb flood light if you prefer, what specific function were you looking for?
I just want to be able to turn it on and off with a group of other lights.
You can turn it on/off manually (from a button in the app) or by creating a rule (I think). But if you want group control, you can request for that feature from Wyze.
