It would be awesome if your cameras would natively integrate with Abode Home Security system. https://goabode.com/
Yes, I strongly second this request. Abode is one of the best smart alarm systems out there and would be a perfect pairing with the Wyze cameras.
Like seriously, get an Abode camera instead of Wyze. U’re just cheap 2 spend in Abode product & want 2 use something cheaper.
Not sure what value your comment adds. Wyze cams are cheaper, but even if they did cost the same, they have better resolution, plus they add things like motion sensors, zoom, constant motion capture, full playback via the app with SD card, and are overall smaller.
Does it include Abode ShotoPhop?
Sorry, that was dumb.
