A few more reasons not to purchase from Wyze…
o Cams can not be setup (connection timeout) when using encrypted DNS (DoT).
o Cam setup wants to know your location; otherwise, you have to type in your WiFi SSID every time.
o An existing cam setup has to be fully recreated to change the WiFI SSID.
o Every time you have to setup a cam, you have to re-enter its name instead of being able to easily select your saved names… how many times do I need to spell our Basement, Driveway, etc.
o Every time you have to setup a cam, Wyze app pushes a bunch of marketing crap at you with no way to escape other than to close/crash the app.
o With ALL notifications disabled, Wyze app still pushes marketing crap at you.
o 2FA authentication just choked with server errors while trying to log into this forum, only to discover I was logged in anyway. And do you really need a Captcha with one-shot 2FA.
These are all dumb issues of Wyze’s own doing, imo. I could go on.
OE
