3.3.5 app Release Candidate Beta Test 2/4/2025
3.3.5 RC:
Version:
  • Android: 3.3.5.b612
  • iOS: 3.3.5(2)
What’s new:
  • Fixed an issue where the sound of Wyze Doorbell Pro and Wyze Cam OG was not turned on when the microphone was turned on in a group. (iOS)
  • Fixed an issue where the passkey should not be displayed in the account tab for Oauth login. (Android)
  • Fixed an issue where the product was still in the shopping cart after placing an order in App Shop.
  • Other bug fixes
On the lookout👍
To all,
Version 3.3.5 b612 just installed. App started up and showed Favorites as expected.
10 cams in a group loaded as expected within 25 seconds.
So far so good.
Started testing.
  1. Person filter on Cam Plus Lite is fixed on Android Wyze 3.3.5.b612. Nice work, it took a while but at least you got it fixed :+1:@trekgod3 @peepeep
  2. Cam V3 manual recording a clip bug is sorta fixed again on Android Wyze 3.3.5.b612. PNG image is still shown in the Gallery, but at least you could see the video clip now without force closing the Gallery app to refresh.
It looks like the “hardware encoder” toggle has reappeared. This disappeared back in December.
Double good.
:astonished: :roll_eyes: :angry:
Awesome. How soon until they release the final version?
This is a Release Candidate and there was not a previous beta.
Unless you see some major issues on this forum over the next couple of days it will probably happen on the quicker side.
Where are you seeing it? I’m not seeing it anywhere (maybe I forgot where it used to be).
@K6CCC,
Originally in Accounts > App Settings.
Then they moved it to individual camera Settings > Advanced.
Then in December they made it disappear.
Now it’s back in camera Settings > Advanced.
Need a score card😕
p. s. Not available in all cams. My V3 pro, WBCP x 3, v4, doorbell v2 all have it. My 3 pan Scan v3’s do not have it.
Why on earth would that be a camera specific setting?
Not available on V2, V3, V3 Pan, Original Pan, OG-Tele. For me only available on V4 and V3 Pro.
Speculating. Either those cams don’t have a hardware encoder or they haven’t gotten around to it yet.
Refusing to address the issue publicly is particularly endearing.
On the Android Wyze 3.3.5.b612:
  1. I seem to get error -10003 when I try to view my Cam V3 in a group and there’s no issue with viewing my Cam V3 individually. This seems to only happen when you install fresh from Google Play (uninstall and install again). I can recreate the issue pretty consistently now, can anyone else? Restarting the cameras, router, and the app doesn’t seem to fix it.
The only fix I seem to find is uninstalling it and installing an older version and updating to the latest beta, but you have to login first and view the camera group and then update afterwards.
  1. There’s also a bug with trying to edit the old Floodlight V1 (with the Cam V3 attached) on the Favourites for “Turning on Floodlight for” x minutes automation shortcut. You can’t modify the time as it will say “delay time is too short”.
