3.11 app, Palm Lock, Lock bolt v2 & Color Bulb v2 Firmware Beta Test 2/12/2026
3.11 Beta:
Versions:
  • Android:3.11.0.b751
  • iOS: 3.11.0(2)
What’s new:
  • Optimized the user experience of snooze notifications
  • Bug fixes
Palm Lock beta:
Version: 1.2.4
What’s New:
  • Fix the issue that some palm locks may fail to recognize palms randomly
  • Fix the issue that some palm locks may fail to wake up randomly
  • Improve battery performance
Wyze Lock Bolt v2 Beta:
Version:1.0.8
What’s New:
  • Fix battery draining too fast issue in some random condition
  • Fix lock fail to wake up in some random condition
  • Improve connectivity
  • Bug fixes
Wyze Color Bulb V2 Beta:
Version: 1.0.2.60
What’s New:
  • Improve the unresponsive control of the bulbs.
Google is on the ball. Android app 3.11.0.b751 is already available in the Play Store.
Nice! Android widgets got a much-needed facelift. :heart_eyes:
Wondering if the same was applied to the iOS app version, especially the Wyze bug for widgets under iOS 26.x Liquid Glass.
What the what?! I haven’t yet checked Google Play Store to see if it’s available to me, but I definitely appreciate the heads-up about this! :+1:
This is more related to 3.x app in general… if you had single-device widgets under 2.50.x (e.g., a widget to open a single cam) and really missed those widgets when they were no longer available under 3.x, go back into 2.50.x and add them, then update to 3.x and they’ll still be on your Android device’s home page. This beta release cleans those widgets up making all the important statuses stand out, especially in dark mode.
3.11.0 (b751) app Android Pixel 7Pro
Record to SD card shows off, even though still recording to SD card, in V3 and V3P cams.
Setting it to on just returns to off when returning to those settings to view again.
Anyone having the anoying problem connecting and you have to hit the retry 5-6 times for it to work?
Jist started with tjis releae.
Android:3.11.0.b751
Connecting to what?
Alerts…
The app connects to all sorts of things, but doesn’t connect to Alerts…
Cams, locks, bulbs, etc.
What are you talking about hitting retry 5-6 times on for it to connect?
You don’t connect to an alert.
Select All > Delete has stopped working
For the past few days, the Select All > Delete function has stopped working. I get a verification prompt, but the deletion doesn’t actually occur. If I select each video one by one, then the videos will get deleted. Is this due to a recent app update? I am using Wyze Beta.
[Mod Note]: Your topic and replies were merged to this Beta announcement topic for better visibility to Wyze.
You can check your app history to see if it updated recently, and downgrade if so. You should report bugs like this in the beta release thread for the app your using, since you’ve opted into beta/bug testing.
Which app version are you running? Android:3.11.0 (b751)?
Yes.
Select All > Delete not working
[Mod Note]: Your new topic was merged to your original topic for context/continuity and to conform to the Community Guidelines. Please avoid cross-posting the same issue as multiple topics.
How do I check app history?
I just reported the bug on the Beta Release thread.
I’m not seeing it where I would expect, which—given the app version you’ve described using—would be this topic:
I suspect that’s why @Seapup was asking about your specific app version before, so your original post might be moved there if you don’t choose to post to that topic yourself. Since that’s an official Beta topic, that would be the best place for you to get visibility on this issue from Wyze, at least here in the Forum. You can also submit an app log describing the problem and optionally follow that up by creating a ticket.
In Google Play Store, you can select your profile icon (upper-right corner), then tap Manage apps & device ➜ Manage and then sort by Recently updated.
Your topic and all replies were merged here (to this Beta app announcement topic) for better visibility to Wyze.
I’m seeing the same issue. Under Android 10 and 12, I get a confirmation, but no events are deleted. Under Android 16, no verification is displayed and the app hangs. I’ll submit some logs and post the Log IDs later today. Please do the same or this bug may work its way into a production release.
Edit: I haven’t forgotten about this… just busy and also finding additional bugs related to the Events section in this beta release. Hoping to get some of it posted this evening with Log IDs and steps to reproduce.
In this app version the timestamp is not showing on the battery video doorbell.
