256GB Samsung MicroSD for $20
This is NOT endurance rated, but it has a 10 year warranty, and it is one of their higher end cards. I have not checked to see if the warranty excludes continuous use, but as long as you don’t volunteer that information, they usually don’t ask for the card back or check anything. It is high temp rated, waterproof, etc, and has high read/write performance.
The Pro Plus is 1 step down from the endurance cards. Higher speeds, lower rated write endurance (but still pretty high). Not officially rated for constant 24x7 writing but have seen plenty using these in dash cams without issues.
As long as you don’t mind the Sonic the Hedgehog theme, its a good deal.
Same price via Samsung’s website - in fact if you have a Samsung EPP account (through employer perks program, school, etc) it is $1 cheaper.
That is the lowest Amazon price ever on that card. Thanks for posting.
https://camelcamelcamel.com/product/B0DQX53MMF
