Having the same issue here with rules not running this morning.
Everything just came back up for me and with no latency.
Does anyone else have a problem with their events page showing the same thumbnail for different cameras?
This is three different cameras, but all show the same camera thumbnail. The video event is the correct camera when viewing and after being viewed it normally updates to the correct thumbnail.
Mine sees fine…
Can’t believe no one else has reported this problem: IOS, Events tab, Edit (pencil upper right), selecting multiple events (checkboxes), Delete, appears to do nothing (deleted event thumbs still displayed), but refreshing shows the events really deleted.
I am not seeing this issue. Could you provide a screen recording of this bug? Thanks!
Just test this and yes same thing happens to me.
Will try and get a video up.
I still have a bug where my thumbnails in the events page are showing the same picture for multiple cameras until I view the event or refresh the page.
Also I’m having a problem when I open a notification of an event the app opens to the event then just crashes. I get the pop up box about sending crash report which I’ve done multiple times.
Lastest iOS
App 2.49.0 (3)
Here’s my screen recording, deleted notifications screen needs refresh post-delete
Can I get you to submit an applog and let me know the log number?
Log ID: 1294917
Log ID: 1294954
To the support techs . Same with my android app. Used to have a pencil and could delete all videos . Now there is no pencil at top right corner to all this. Every since like 2 updates ago. Do you know when this will be corrected ASAP please??
Thank you
FWIW, I only got a few things setup since moving. Only the vdb v1, 2 bulbs, 2 plugs. With iOS app 2.48. I had app crash routinely when I tapped on a db notification to open the app. Also had a random bulb or plug ignore the “off” schedule rule. I fixed that by adding redundant rule in Alexa to trigger 2 min later.
So far 2.49 is doing ok for the notification to open app without crashing. Although we have very few motion events, so not a lot of opportunities to check it out.
