170 degree lens
Hi all, any of you seen or used this 170 degree lens for WYZE cam selling on Amazon if so, is it any good or would you recommend it, is it an easy DIY, or is it worth it.
Thanks
170°Wide Angle Lens for Wyze Cam V2 V1 and Ismart Spot Camera, 3.6M Focal Length, Can Work with Any Wyze Case Cover and Mount https://www.amazon.com/dp/B082NN7LR2/ref=cm_sw_r_cp_api_i_yekeEb17VXZWS
I haven’t seen it until you just mentioned it so I don’t know how it works. But to me it kind of looked a little fish-eyed and I’m not sure I would like that look. So why don’t you go ahead and be an early adopter buy one and install it and then show us how it all worked out for you. :grinning:
